I have this device called an "icush". It is a seat cussion with message motors and audio speakers in it with an attached controller for the following functions:
Power
Audio Sync
Message mode
Speed
Intensity
It runs off an a 12VAC adapter.
The adapter seems OK, it measures at least 12V and does not cut in or out when moving the wire around.
When I plug the power adapter into the seat pad the motors and audio are energized for about 1 second then it stops. When I remove the power from the seat pad there is about a 1 second delay and then there is a very quick recurrence of audio, but not enough to cause the motors to move.
After opening the controller unit I was greeted with a host of led's, momentary switches, a handfull of resistors, and 1 IC chip.
I don't think there's anything but motors and 2 speakers in the cussion, based on my touching the seat pad all over.
Any ideas on what might be causing this??
Appreciate your thoughts.
Power
Audio Sync
Message mode
Speed
Intensity
