Diagnose a circuit on a car's brake assist control module )
cadman777
Joined Dec 23, 2022
53
I'm in the process of trying to diagnose a circuit on a car's brake assist control module because it's failed.
The module is no longer available, so I'm resorting to trying to fix it.
However, it's all smd, and has components on it that have no identifying marks on them.
So I was wondering if there is a forum in here that specifically addresses these issues?
Thanks...Chris
18,184
Don't worry about it. A moderator may come along and decide it belongs in Technical Repair or some other category, but that's not terribly important. I think most folks here follow all the posts and don't much care where they are pigeon-holed.
Your best bet may be an owners forum for the vehicle(s) that used that particular control module. If you're lucky, others have found a common point of failure and you can leverage that hard-won knowledge. If not, it may be very difficult to make headway beyond careful inspection for obvious problems on the board such as burned components, broken traces, etc.
More details about your vehicle and pictures of the module might help you get more feedback. Good luck.
cadman777
Joined Dec 23, 2022
53
Thanks for your input, Wayne. Yes, I've been to all the forums and they don't really know much at all. I'm operating at a different level than they are since I've been a mechanic since the 70's. Most of the people in those forums are either 'weekend warriors' or ASCE certified techs in their own particular Y/M/M realm. Most of the time they don't get past 'changing parts'. It's bad enough that diagnosing electrical and electronic problems in modern vehicles is a full time speciality. But add to that the need to RE and repair a bad module, and you add one too many levels of complexity to the game. So that's why I'm in here. You guys are the specialists in this stuff.
So, I'm working on a low mileage 1999 Mercedes W202 class sedan. It's got a brake system that's amazing. But the components are no longer available, and the electronics (and other parts, like plastics and rubber) are getting old and need help. This particular part is the BAS module (brake assist). it's part of the ABS/anti-skid/traction system. Anyway, it has 3 systems on it, and one of the circuits on one of the systems is not working right. I already tried fixing it the way you said, but since I can't get a service/diagnostics/schematic manual on it, I'm 'on my own'. Incidentally, recently the radio on this failed. I opened it up to find corrosion in one area. After many searches online, I found the official service manual/schematics/parts list for it. Using a microscope I found the burnt trances and a bad via, and fixed them. While in there I also replaced the SMD's and an IC. Now, that radio (Becker brand) works as good as new. Turned out to be the 'wake-up' circuit. No telling why it went bad. Probably just old. I replaced the main power caps too, just for the sake of PM. So, I've recently been into this sort of thing, which encouraged me to try to diagnose and fix this BAS module.
Regarding the BAS module: I've been trying to RE the PCB in KiCAD to help figure out what might be causing the bad 'net'. But I can't identify a number of the parts. So I need help with that (since I'm no electronics expert). I also need help on understanding how the circuit works. So far I've replaced the only electrolytic capacitor on the board (it showed signs of leakage), the 8-pin IC in the offending circuit, and a tantalum cap that was near the leaking electrolytic cap. When I plugged it into the car and took the voltage measurements, they were basically the same. So I obviously didn't fix the problem. Maybe the electrolytic cap needed replacement, and the other parts didn't?? But whatever is wrong with it still needs to be determined.
There's a lot going on in this little PCB. The offending circuit is the output communications line that's on connector-3, pin 6. It goes to the DLC pin-8. It's supposed to communicate with the ECM, from whence it gets its instructions on the kind of vehicle it is, so the BAS module can select the correct dataset for using in the 'brake assist' computations/operations. The dataset has to do with horsepower, torque, wheel rotation (ABS sensors), speed, etc., which are all vehicle specific. What happens is C3/P6 sends a 1v-2v signal to the ECM, which in turn (don't ask me how) tells the BAS module which PARAMETER to set. That parameter determines the vehicle dataset I just told you about. As it is, C3/P6 is outputting 3.21 volts (supposed to be btw 1-2v). So, I need to get this circuit communicating properly so the ECM can tell the BAS module which dataset to use.
Here are pics of the front and back sides of the module:
(back side mirrored to match the front side to help prevent confusion when tracing 'nets')
Lower left smd cap and top middle 8-pin IC were replaced. So was the orange cap to the right of the 20 pin IC. The connector pins run along the bottom in 3 groups. The pin of interest is the left most at bottom.
I looked closely at the board through a binocular microscope and didn't find any burnt anything. but there appears to be milky stuff in various places, as you can see, esp. on the back side. But the solder didn't look bad, so I didn't pay it any never mind.
When I first worked up an order for parts (DigiKey), I misjudged the circuit. Since then, been at the RE work for two whole days and not done yet. That single connector pin goes directly to the 8-pin IC, and branches off all around the board from there. So at this point, I'm in over my head and need help b/c I'm not an electronics tech.
Thank you for your interest and willingness to give me some help!
cadman777
Joined Dec 23, 2022
53
btw, what kind of tools/instruments you have at your disposal? scope, logic probe, DMM, ...?
2 channel scope with leads
dmm
wave generator
hot air and temp regulated soldering stations
various and sundry electronics and electrical parts and supplies
only thing is, i'm kind'a rusty on using the scope, since it's been many years since using it
but i do use a scope to get waveforms on vehicles, but it's not quite the same thing
no logic probe (wouldn't know how to use it)
panic mode
Joined Oct 10, 2011
5,475
things i would normally check first:
1. try to power it up and measure voltages. wider traces indicate pwoer rails.
2. identify all major part numbers and check their datasheets. this is how you get info what voltage is expected and where etc.
3. check if MCU is working. if there is any sign of life (scope or logic probe needed). if MCU is toast, product is usually beyond repair... nless you are ready for some punishment. for example if MCU is damaged but still responds it is great if one can read the code back. then one can try to replace it using part from a donor board or where ever you can source it, and flash it... but i would not hold my breath. there is a good chance that reading back is blocked by blowing internal fuses.
4. probe peripherals and see if they show normal voltages... for example CAN bus is easy to check. and many scopes can decode data too.
5. check for blown fuses, shunts etc. if you have FLIR, check for hot spots.
cadman777
Joined Dec 23, 2022
53
There's a blob of solder, where the arrow points, which might be shorting the trace to the ground patch.
Thanks for taking a look at it Alec. I rechecked it under the microscope, and discovered that it's an air bubble captured under the conformal coating. Thankfully, there are no signs of shorting on the board. Thanks for your sharp eye!
Here is an updated front side of the PBC. I connected all the bottom traces.
Notes:
The red lines are the bottom traces.
The red donuts are the vias (front side to back side thru the board).
If there's no line touching a red donut, then it's got no traces on the back side.
If there's a red 'X' in a red donut, then it's connected to a large copper pad (which see on back side of board).
Since I've not detached all the components that have hidden vias and traces under them, I can't tell where the back side vias attach on the front side. I can only guess!
Remember: I mirrored the back side of the board horizontally in the previous pic to make matching-up vias and traces easier. Took me the better part of 6 hours to do this graphic! Thanks to the folks who created "Paint.Net"... fabulous 'paint' program!
cadman777
Joined Dec 23, 2022
53
1. try to power it up and measure voltages. wider traces indicate power rails.
3. check if MCU is working. if there is any sign of life (scope or logic probe needed). if MCU is toast, product is usually beyond repair... unless you are ready for some punishment. for example if MCU is damaged but still responds it is great if one can read the code back. then one can try to replace it using part from a donor board or where ever you can source it, and flash it... but i would not hold my breath. there is a good chance that reading back is blocked by blowing internal fuses.
Wow! Thanks for this info!
OK, lots to do!
Notes:
1. I have already tested it in the vehicle at the connector pins, but not out of the casing and touching places on the board. I don't know where to begin, since I don't know what's supposed to do what and what is supposed to control what. That's why I came in here, to try to figure out what each component is and then model it up in KiCAD.
2. Still working on it, but some of them are not easy to figure out. I removed all the coating on the tops of all the IC's and got all the numbers off all the IC's and the MCU (removed the bar code sticker too). Tried looking up the MCU and couldn't find anything. That's not saying much b/c I'm not an electronics guy.
3. I hear ya. Not sure how to test it. But I can get the data from Benz for the connector pins, which is a start. I'm working on gathering all that info and 'modeling it up' to create a record of it b/c there's no way I can remember all of this!
Far as donor boards is concerned, I already purchased 4 used modules, and they all have the same problem. The latest one that arrived yesterday. Before buying it I verified with the seller that it was good. But when it arrived it had signs of electrical power arcing inside one of the connector sockets. And THE pin (the one that's got the bad circuit in the original module and also on all the other used ones) was totally missing! So, this may be a 'known defect' for these modules which MB refuses to take responsibility for. Anyway, I don't hold out any hopes for finding a 'known good unit'. If I could, I wouldn't waste time doing this RE work. Instead, I'd just swap-out the parts and be done with it. Same with the rear door control module that's integrated into the window motor. It caused a coms DTC on the interior CANbus. Tracked it down to the CAN-H line on the left rear door module. The connector socket showed signs of overheating, b/c you could see the power line all 'browned-up' in the clear yellow gel. So, something happened there which killed the CAN-H circuit. Anyway, I just disconnected the CAN-H line and let the 'reserve' CAN-L line do the coms work, and it works fine now. A new motor/controller is around $250. Can't afford it. One day I may try to fix this one, not sure, b/c it's gonna be a real DOG to take the PCB out of for testing purposes. Anyway, a new BAS module, IF it exists today (many OEM online sellers list availability until you buy it, then they tell you it's NLA), is listed at over $1000, whereas back in the day they were around 60 bux!
4. Already did all of that. They all check 'good' except the "Diagnostics" line (C3/P6). The module works otherwise, but it's operating on the wrong data ("Parameter 5": for a more powerful engine and heavier vehicle. That's wearing out the brakes too quickly, so I wanna get it fixed.
5. Already did that. Don't have a FLIR, but was 'dreaming about' getting one. Been waiting for 5 years for the resolutions to come up and the prices to go down first.
6. Based on your 'mark-up' in the pic, my next job is to make a representative PCB component block diagram like the Becker service manuals have for their radios. They'll have all the part #'s on it that I can find.
It's gonna take some time to get all this done, after which I'll be back in here with results.
Thanks for the input!
cadman777
Joined Dec 23, 2022
53
Here's the component block diagram:
Notes:
- This is an overlay for Paint.Net (which is where I created it) of the original PBC board front-side that's posted above.
- All unmarked components do not have marks on them.
- The 3 groups of circles at the bottom are the connector pins.
- The offending circuit is on pin-6 all the way to the bottom left.
Back before the internet, I had books I'd use to lookup these components.
But not any more, which means I need sources to find them.
What I usually do is call DigiKey and ask one of their techs to help me find them or their equivalent in their catalog.
But DigiKey isn't always the right source to get these parts from.
Sometimes it's fleaBay, other times it's another mfgr.
If you can tell me where I might find these components, I'll do more searching on my own.
Thanks for the help!
cadman777
Joined Dec 23, 2022
53
Here is a diagram of the circuit that's not testing correctly:
Notes:
- It's not connected to that alum.-elec. cap.
- It is connected to the micro smd cap near pin-6.
cadman777
Joined Dec 23, 2022
53
Attached is the spec sheet for the 9241 IC.
The relevant info is as follows:
The K & CS are connected to each other on this board by a trace, so this is non-CS and K-line only coms.
Looks like I need to somehow reconnect this module to the vehicle, connect up the scanner, and then probe the TX & K signal at the SO-8 to see what voltages they have. The thing is, in the past with the scanner hooked up, sometimes the K-line was open, and other times it was closed. So, no telling why. Is it possible that the ECM is sending 'mixed (voltage) signals'? Of could the problem be on the board, where some components are not allowing the TX to be the correct voltage (or it's fluctuating) so the 9241 chip malfunctions? The field measurement was this: too high voltage on the K-line at the connector socket pin-6. Am I interpreting the above explanation correctly when thinking that the high voltage means the K-line IS transmitting, but the voltage is wrong, so the ECM can't communicate with the chip? If that's correct, then wouldn't the problem be on the board and not in the ECM (the TX signal)?
cadman777
Joined Dec 23, 2022
53
Below is an update after powering up the c3 connector but not connecting the other two connectors (one of which goes to the brake diaphragm travel sensor and the other to the vacuum release valve (it's a dual chamber vacuum brake booster):
Here are the voltages for connector 3
c3p1: 0 (ground)
c3p2: 2.61 (can-h i/o)
c3p3: 13.8 (bat in)
c3p4: 13.8 (bat in)
c3p5: 2.4 (can-l)
c3p6: 3.67 (k-line/diagnostic i/o)
Here are the voltages for connector 2
c2p1: 12.12
c2p2: 12.12
c2p3: 0.6
c2p4: 0
c2p5: 0
c2p6: 4.71
Here are the voltages for connector 1
c1p1: 5
c1p2: 0
c1p3: 0
c1p4: 0
Here are the voltages on the 9241 chip:
p1: 5.02 (vdd)
p2: 5.02 (tx)
p3: 0 (cs - jumped to tx)
p4: 5.02 (fault)
p5: 0 (ground)
p6: 3.67 ('k-line'/'diagnostic' - this is the bad circuit)
p7: 13 (vbat)
p8: 0.04 (rx)
@panic mode: "3. check if MCU is working. if there is any sign of life (scope or logic probe needed)."
I can't find an official MCU schematic online.
Can you (or someone else) help me find one?
Find attached another cutsheet on the 9241 chip.
P4 shows the chip layout and identifies the pins.
Thanks for helping!
narkeleptk
Joined Mar 11, 2019
599
what do you mean 3.67V is "too high"? K-line voltage is up to Vbatt (14.5V).
I too have been perplexed by this. TS said that "As it is, C3/P6 is outputting 3.21 volts (supposed to be btw 1-2v)."
The way I understand it is that the K-line should sit at B+ when idle and gets pulled low when active. There should be no 1V–2V operational state. The 3.21V reading sounds like it's being taken without the ecu connected (I assume where the B+ pull up is since I do not see it on this board) or the meter is averaging out a data stream.
@cadman777
Out of curiosity, where did that 1–2V spec come from?
cadman777
Joined Dec 23, 2022
53
Thanks.
That's the one I found based on @panic mode's post #8
But it's generic, not specific to the Lucas BAS module.
Are these all the pin functions the same execpt for maybe internal coding of some kind?
Anyway, I just finally took the time to read the entire document (skimmed most of it!).
Found the chip layout that I was looking for...Excellent!
Also printed the pin functions so I can update my KiCAD schematic.
'Now we're cooking with gas!'
cadman777
Joined Dec 23, 2022
53
According to StarTech (Mercedes old FSM), the voltages on the K-line are supposed to be between 1v-2v. If they are out of range, then they cause a communications error with the ECM, which is why I'm into this in the first place. Unless the ECM can com with the BAS module, the BAS module won't know which pre-programmed dataset to use for its functions. The way that happens is the ECM sends the BAS module the VIN and other data, which the BAS' MCU uses to select the correct 'Parameter', which is the 'tag' for the module to load the correct stored-onboard (in the MCU?) dataset. So, for example, if the vehicle is a v8, the BAS module will set Parameter 3. But if the vehicle is a 4 cylinder, the vehicle will set Parameter 7 (I made up those numbers for illustration purposes). Moreover, there are many other variables in the dataset per parameter number that have to do with the vehicle's weight, HP, brake system (size of rotors and type of actuation), etc. So there are more than one parameter even for each 4 cylinder (or 6 cyl, or 8 cyl, etc.), depending on its 'options'. Anyway, the pin-6 voltage is supposed to be between 1v-2v and not under or over, otherwise, ECM/BAS won't com. That's what I'm trying to fix. That's why there's a DCT of C1025 and sporadic "can't communicate with BAS module" error when trying to connect.
See for yourself:
The thing that troubles me is seeing all those 5.02v on the Si9241 chip pins. If the CS & Tx (p2 & p3) are jumped by a trace on the board, shouldn't they be the same? Why is CS 0v when Tx is 5.02v? Incidentally, I believe that the (1.1) and (1.6) are errors. They should be (3.1) and (3.6) b/c they are on connector #3, and b/c there are only 4 pins on connector #1. So, what I'm trying to figure out is what controls the output of c3/p6 on the BAS module circuit? I know that it's the Si9241 chip. But, what board components on that chip's five circuits control that output?
narkeleptk
Joined Mar 11, 2019
599
Its not generic at all. 0D69J is a specific motorola mask set identifier for the mc68hc05x32/mc68hc705x32. The mask on the chip is not related to Mercedes or their coding, so yes its the same pin out function as whats in the datasheet.
https://www.nxp.com/docs/en/errata/68HC05X32MSE1.pdf
I've done a lot of working with these chips in benz modules (and other manufacturers) . It was very commonly used in late 90's-early 2000's.
About the diagram,
The1–2V spec is a bit misleading cause they are having you take the measurements with a voltmeter while the line is active. Its not a steady DC output in anyway, it's what a meter might average the pulses out to be. This will vary depending on the dmm used. The STAR SI is probably giving this data assuming your using the exact dmm they specify for their techs. Your 3.2V is likely normal for your meter trying to average this data transmission.
If you use your oscilloscope you will see what's really going on, you will see it being held high (B+) and getting pulled low repeatedly (if hooked up to ECU anyway). That would mean that the circuit up to the K pin on si9xxx in BAS is working. So your next step would be to check RX/TX side and see if they are sending data between si9xxx and the mcu. Since you stated the module mostly works but seems like its incorrectly coded then I think its pretty safe to say that it is receiving data.
Assuming you have proper pull up from ECU, I think the way you adjust the things you mention is by coding the module with DAS. Its not going to be determined by what a voltmeter reads.
