Diagnose a circuit on a car's brake assist control module )
cadman777
Joined Dec 23, 2022
53
Its not generic at all. 0D69J is a specific motorola mask set identifier for the mc68hc05x32/mc68hc705x32. The mask on the chip is not related to Mercedes or their coding, so yes its the same pin out function as whats in the datasheet.
https://www.nxp.com/docs/en/errata/68HC05X32MSE1.pdf
I've done a lot of working with these chips in benz modules (and other manufacturers) . It was very commonly used in late 90's-early 2000's.
About the diagram,
The1–2V spec is a bit misleading cause they are having you take the measurements with a voltmeter while the line is active. Its not a steady DC output in anyway, it's what a meter might average the pulses out to be. This will vary depending on the dmm used. The STAR SI is probably giving this data assuming your using the exact dmm they specify for their techs. Your 3.2V is likely normal for your meter trying to average this data transmission.
If you use your oscilloscope you will see what's really going on, you will see it being held high (B+) and getting pulled low repeatedly (if hooked up to ECU anyway). That would mean that the circuit up to the K pin on si9xxx in BAS is working. So your next step would be to check RX/TX side and see if they are sending data between si9xxx and the mcu. Since you stated the module mostly works but seems like its incorrectly coded then I think its pretty safe to say that it is receiving data.
Assuming you have proper pull up from ECU, I think the way you adjust the things you mention is by coding the module with DAS. Its not going to be determined by what a voltmeter reads.
Wow! Lotta good insider info, thanks!
"Its not generic at all."
Nice to know!
Gives me confidence that the info in that pdf is accurate and useful.
So, when I hooked up hhtWin to the 38 pin DLC, I could not find any coding function for this module.
Everything I read says it's auto-coded when by the ECM when they communicate.
Is there something I'm missing in hhtWin?
Meanwhile, first chance I get I'll hook up my Pico to c3p6 and see what it gives me.
Is the Rx/Tx the CAN-H&L lines?
I already scoped them and there's definitely data on those lines that looks right.
But if you mean to test it on the board, are you saying to check the Rx/Tx function with it installed in the vehicle, or powered/grounded on the bench and use my bench scope?
narkeleptk
Joined Mar 11, 2019
599
When you say to check the Rx/Tx function, do you mean with it installed in the vehicle, or powered/grounded on the bench?
Easiest way is with the ECU connected.
If you do it on the bench you would need to supply the pull up and wake up signal on C3/P6.
Possibly a good scanner would provide both and then you could take some readings but I'm not familiar with this module so not 100% sure on that.
cadman777
Joined Dec 23, 2022
53
OK, thanks.
But I can't test it while connected to the vehicle b/c there's no room to do the testing (harness leads too short).
I'm have no idea how to create/do the bench test line signal.
cadman777
Joined Dec 23, 2022
53
Today I scoped the K-line and CANbus.
The K-line worked as expected.
The CANbus did not.
CAN-H was near 0v, which means, according to StarTech, it's shorted to CAN-L somewhere.
There are 7 modules on the engine-side CANbus.
Last time I checked the CANbus it was OK, which is why I didn't question it.
The CAN-L signal is not 'clean', not sure why yet.
So there's s short somewhere that I need to find which might be starting to impinge on the CAN-L line.
Oh boy, time to dig-into the wiring, connectors, junctions and modules...what fun!
It's possible/likely that the BAS modules I've plugged in have been good all along.
But I can't find anything in the Benz repair info that tells me what the relationship is between the CANbus and K-line systems.
One thing that troubles me is I have a 'GoDiag GT100' breakout box that I connected to the 16-pin DLC.
But it didn't seem to feed the right signals into the scope.
If it doesn't work with K-line, then that was a grandiose waste of money!
Anyway, if the CAN-H is bad, and the CAN-L is sketchy, would that impact the K-line coms for setting the correct Parameter in the BAS module?
