DIAC IV Curve With Oscilloscope.
aragon1971
Joined Apr 7, 2008
160
hi a have the following circuit how i must connect the ch1 and ch2 of osciloscope to find in xy mode the IV curve of diac.
The circuit is follow
AlbertHall
Joined Jun 4, 2014
12,637
If the AC source MUST be floating. Connect the scope ground to the junction of diac and R2 or R3 depending which you are using. Connect the Y channel (voltage) to the top of the diac and the X channel (current) to the AC GND. Invert the X channel to get the correct polarities. This will display the IV curve on the scope.
aragon1971
Joined Apr 7, 2008
160
thank you the ac signal come from a tapered transformer 220 vrms from network convert to 36 Vrms is this case the ac signal is floating or not ? (see attachment)
AlbertHall
Joined Jun 4, 2014
12,637
It looks like it is floating. To be sure, with it switched off, measure the resistance between one of the AC outputs and the mains earth pin. It should show a very high resistance or overrange.
drc_567
Joined Dec 29, 2008
1,156
... This thread is interesting and informative. If it is not too much trouble, could the original poster give us a screen shot or diagram of the resulting scope image?
