Diac connected to the gate terminal of an SCR
alejandrogm7751
Joined Nov 1, 2018
Greetings from Venezuela, I would like to know how prudent it would be to connect to the gate terminal of a SCR TYN612T, a Diac DB3, as repairing a control card of a small AC motor, I found that is regulated with an SCR and the same has in the gate terminal A Diac, I shouldn't have a diode, right?
MaxHeadRoom
Joined Jul 18, 2013
30,890
Is this a repair or design?
A diac is usually used in the gate of a Triac, for a SCR a diode is often seen in the gate circuit.
Used to prevent excessive reverse gate voltage
Max.
ian field
Joined Oct 27, 2012
6,536
The diac is more or less a triac with no gate pin - its triggered more or less by breaking down at a reasonably well defined voltage level. They're not exactly rare in gate circuitry.
They're getting a bit hard to come by - there's one in most higher rated CFLs.
ian field
Joined Oct 27, 2012
6,536
So is the original Diac OK, If not then you most likely could sub for a diode.
Max.
There is no way a diode and diac are interchangeable. Anyone I need to explain a diode to shouldn't be here. A diac is a triac with no gate terminal - its triggered by breaking down at a specific voltage.
ian field
Joined Oct 27, 2012
6,536
According to the well known 731 page reference "SCR Manual" published by General Electric semi conductor dept., all SCR circuits and examples use a diode on the gate, the Triac however uses the Diac.
Max.
By "diode" - are you referring to the 4 layer 2 terminal devoces that do (or did) the same thing for SCRs that diacs do for triacs.
no idea whether any manufacturers still make those polarised 4 layer breakdown devices - but the slightly less unobtanium diac will do the job if its breakdown voltage is similar.
