Determining Ic saturation current for common emitter voltage-divider amplifier ..#2
Sar1
Joined Mar 12, 2022
Hi
Can anyone tell me the deference between
In transistor the Ic sat =0
But
In circuit the Ic sat = the highest value???
Papabravo
Joined Feb 24, 2006
22,111
Hi
But
A transistor cannot have a collector current of 0 and be in saturation. A collector current of 0, describes the condition of cutoff.
Try to rephrase your question in a more meaningful way.
Also, the maximum value that the collector current can have depends on the collector resistor. In saturation the collector current will be:
\( I_C\;\approx\;V_{cc}/R_c \)
It will be a little bit less than that value because, even in saturation, a typical transistor will have a Vce voltage drop 200 mV give or take a bit.
