Audioguru again
- Joined Oct 21, 2019
- 6,826
The mechanical vibration sensor detects earthquakes and other very low frequencies up to 100Hz which is a low audio frequency. It is most sensitive at 40Hz which is a very low bass frequency. It does not detect higher audio frequencies.
A piezo sensor is sensitive at a few high frequencies (3kHz to 6kHz) and has poor sensitivity for frequencies less than 1kHz.
A piezo does not conduct then the image above is missing a biasing resistor for the +input of the opamp. Also it is missing a voltage clamp to prevent a high voltage generated by the piezo when it is struck from damaging the opamp.
