detect whether current is ac or dc
johnboyman
Joined Jun 1, 2019
43
Hello I have some circuit board that I am trying to repair for one of my appliances but I can't figure out if some parts are ac current or DC and don't want to break my multimeter. Are their ways to tap a circuit and find out weather it has ac or dc current running through it. Thanks.
dl324
Joined Mar 30, 2015
18,449
You can determine that from the schematic.
How can you break your meter? DVM's should be able to measure positive or negative DC current. With alternating current on the DC current scale, you should measure 0.
Glenn Holland
Joined Dec 26, 2014
703
If you're trying to find out "weather" it's AC or DC, current, you need to use an outside thermometer the measures the current temperature.:)
rsjsouza
Joined Apr 21, 2014
430
@johnboyman, are you trying to measure current or voltage?
At any rate, the safest way to find out if a specific point in your circuit has AC or DC or a combination of the two is to use the Volts ranges of your multimeter. Differently than the Amps (current) ranges, the Volts ranges has a very high impedance and therefore much harder to make mistakes.
In addition to the suggestions above, even if you measure a point as AC or DC, keep in mind it may not be "pure" but maybe a sum of the two. To be absolutely sure, make two independent measurements at each point (DC and then AC). Always take @dl324 suggestion as well: start with the highest range.
AnalogKid
Joined Aug 1, 2013
12,238
Start with the meter on an AC range, and see if there is a significant reading. If not (after the initial transient), then move to a DC range.
ak
