Circuit to detect whether capacitor is charged and trigger LED
icydash
Joined Jan 14, 2009
148
For part of a project, I need to build a circuit that can detect whether a 100 pF capacitor is charged to at least a threshold level (e.g., 90%) and, if so, turn on an indicator light. I'm not really sure where to begin, since I don't have much of an electronics background.
Is there also a way to detect if the capacitor has discharged and trigger another indicator light? My goal would be to have a green light turn on if the capacitor is above a threshold charge level and a red light turn on once it discharges.
dl324
Joined Mar 30, 2015
18,476
You can use a comparator. Since the capacitor in question is small, you'll want one with MOSFET or JFET inputs so you don't have to worry about the comparator discharging the capacitor.
icydash
Joined Jan 14, 2009
148
Thanks! So would I attach one of the capacitor's leads to one of the competitors inputs, and then do like a voltage divider for the other comparator input lead?
dl324
Joined Mar 30, 2015
18,476
Yes. Put the reference voltage on the non-inverting input and the capacitor voltage on the inverting input. When the capacitor voltage gets above the reference, the output will go to about ground.
You'll want to use something with a lower input current then LM393. The other comparator can be used for your red LED condition.
icydash
Joined Jan 14, 2009
148
Thanks very much. Yes the current will be very very low, and the voltage will be pretty high on the capacitor (around 10kV). Do you have any recommendations for comparators that would work with those specifications? (Preferably through-hole for easy breadboard testing).
38,848
It'll be a pretty high voltage with very low current. Around 10kV on the capacitor.
10kV. :eek:
Well that's a small detail that makes a huge difference!
Sorry, there is no IC comparator that will work any near that voltage.
How low is a "very low current"?
You might be able to use an electrostatic voltmeter, but they aren't cheap.
dl324
Joined Mar 30, 2015
18,476
What is the charging current? Operating with 10kV will require a voltage divider and typical resistors only have a working voltage of a couple hundred volts. Either you're going to have to use a lot of regular resistors or you're going to need to use some resistors with a high working voltage.
Need to know the charging current and the charging time involved. For starters.
icydash
Joined Jan 14, 2009
148
10kV. :eek:
I wonder if I could just step down the voltage on the capacitor until it's in a normal 3-5v range for purposes of the comparator. Like, create a voltage divider that divides the voltage on the cap by 2000, so that it's at a lower level for the comparator.
icydash
Joined Jan 14, 2009
148
I'm just using a 3.3v battery with some voltage multipliers to achieve the 10kV needed for the cap.
38,848
I wonder if I could just step down the voltage on the capacitor until it's in a normal 3-5v range for purposes of the comparator. Like, create a voltage divider that divides the voltage on the cap by 2000 so that it's at a lower level for the comparator.
That's possible.
But need to know the current available for that purpose, since all resistive dividers take current.
Even a 1GΩ divider will draw 10µA @ 10kV.
icydash
Joined Jan 14, 2009
148
That's possible.
Was just gunna use a 3v watch battery (button type). Not sure of the current output on those. Maybe like 110mAh?
38,848
mAh is the battery capacitor, not the amount of current it can output.
And the current output will be greatly reduced at 10kV.
Even for 100% conversion efficiency the current would be reduced by the ratio of 3V/10kV, so 100mA from the battery would, at best, equal 39µA @ 10kV.
Ya’akov
Joined Jan 27, 2019
10,307
Pointing it out only to avoid confusion, something autocorrected capacity to capacitor in your post.
[EDIT: edited to avoid more confusion]
icydash
Joined Jan 14, 2009
148
Thanks. But if I do a voltage divider to step down the voltage from 10kV to something the comparator can handle, won't that also increase the current to the comparator? For example, if I did a voltage divider to step down the 10kV to like 5V (e.g., a voltage divider that divides by 2000), won't that simultaneously increase the current to the comparator as well into a more normal operational range?
Irving
Joined Jan 30, 2016
5,195
No reasonable resistor divider is going to work...
Q = CV = IΔt -> Δt = CV/I
C = 100e-12
V = 1e4
I = 10e-6 assuming 1GΩ resistor network
Δt = 100e-12/10e-6 * 1e4 = 100mS
Your measuring approach will discharge the capacitor faster than you can blink! It may be charged to 10kV but the amount of charge is tiny.
Obviously if you're measuring while charging it then that's less of an issue but as soon as you stop charging the charge will leak away. Anyway, constructing a multi-GΩ resistor of any reasonable/meaningful accuracy is nigh-on impossible outside of a specialist lab.
What is the purpose for this charged capacitor? Give us more background and maybe some other approach will become clear...
(and a 3v button cell isn't going to deliver either!)
ElectricSpidey
Joined Dec 2, 2017
3,359
Technically speaking it won't increase the current to the comparator, but as explained it will provide a separate discharge path for the cap.
BobTPH
Joined Jun 5, 2013
11,660
Voltage multipliers will not get you from 3V to 10KV. Do you actually have a working circuit? If so, please post a schematic.
Bob
icydash
Joined Jan 14, 2009
148
Bob
What's the smallest battery I could use to get to 10k? Is there another way, like using a step up transformer, that might work better than voltage multipliers?
I don't already have a working circuit right now. I'm still thinking it through. It's all hypothetical right now and everything, other than the 100pF capacitor and 10 kV charge level, can be changed as needed. Those two factors are outside my control.
