Thank you, nsaspook, but what you are seeing is just a prototype mocked up in my shop for testing purposes. The real one hopefully will look better. And won't have all that harmonic vibration from the rubbing as the door retracts.I don't see a problem with a single fuse of the correct amperage for both motors
I've worked on lots of older seal door systems where there are separate actuators for seal/unseal and open/close. Most modern systems use a cam-over or auto-lock pressure seal operated from one actuator.
Great job on that woodwork.
You've peaked my interest though. Do you have any convenient links to "cam-over or auto-lock pressure seal operated from one actuator", in that I'd have never heard of them when I was doing my initial research, they somehow escaped me. (Actually, I did sort of think I was re-inventing the wheel, sort of anyway). As I've done a dozen or so hidden doors, I was aware of those little things that give them away. Large gaps at the bottom, gaps between the frame and door/cabinet/ whatever moves.
Chris
