Designing a RLC with 0 damping
Samantha Groves
Joined Nov 25, 2023
180
I got a idea of designing a RLC circuit with 0 damping.I was working with tunnel diodes.
In a tunnel diode the IV curve looks like this:
We have 2 currents , the tunnel current \[ I_{dt} = I_{pt}\frac{V_d}{V_{pt}}e^(1-\frac{V_d}{V_{pt}}) \]
and the normal current of a PN junction:\[ I_{ds} = I_s e^(\frac{V_d}{V_T}-1) \]
If you set a operating DC point on the tunnel and assume that the variation under AC is small the AC resistance becomes:
\[ r_{ac} = \frac{V_{T}}{I_{dc}}+\frac{V_{pt}^2}{I_{pt}}\cdot\frac{1}{V_{pt}\cdot e^{1-\frac{Vd}{V_{pt}}}-e^{V_{tp}-V_{d}/V_{pt}}\cdot V_{d}} \]
This comes from differentiating the current of the diode with respect to the voltage of the diode and assume a fixed operating point.It is the same as in normal diode , now that we have the tunnel current the ac resistance becomes a little more complex
But V_pt and I_pt are constants of the tunnel diode , V_pt is the voltage just before we enter the negative differential region and I_pt is the current just before we enter the negative differential region.
And if you draw this on desmos you get this part:
https://www.desmos.com/calculator/ge7oq0psuw
As you can see if we set the operating very carefully we can get a negative AC resistance for the tunnel diode(I neglect the VT/Id part) since for very small current Id which we will be working it can be neglected.Now lets look at a typical RLC circuit:
If C2 is charged then depending on R1 and L1 the system will gradually reach 0 due to losses in the resistor.The idea is to use the negative ac resistance of the tunnel diode to balance out the positive resistance of a positive resistor.Will this work?
28,525
I was just going to submit that it is the resistance term that leads to the damping. It gets complicated in negative resistance circuits like tunnel diode circuits and gas discharge tubes where as the current increases so does the conductance.
THis is why you seldom see tunnel diode circuits in new designs.
