plugnplay
Joined Mar 24, 2022
8
Hello all,
I am currently working on a project where I have to divide a 100 MHz frequency by n. where n could be any integer1,2,3,4,...9. where I want to give these n integer from external keypad or any software control. Is it possible to do it with #microcontroller based system or FPGA system? I tried with D flip flop where I can only get 2^n division factor.
Thanks in advance.
dl324
Joined Mar 30, 2015
18,521
Professionals use PLL's (Phase Locked Loops).
From Signetics:
EDIT: better example showing fractional synthesis.
dl324
Joined Mar 30, 2015
18,521
Is it Possible to add 1/n manually in this PLL?
Part B of the diagram showed how to do that. You just add a counter in front of the PLL.
BTW, the block diagram isn't for any particular part. It just shows the concept of generating \( f_o=\frac{N}{M}f_i \). You use whatever you want to implement the functional blocks. I included the company name for proper attribution. The concept is widely used in microprocessors, past and present, to generate clocks.
In the commercial parts I've seen, they include the phase comparator, amplifier, and VCO. You provide the low pass filter and any dividers.
