Designing 10A constant current power source (0-50 V)
johnpete001
Joined Jun 26, 2017
6
I want to design 10 A constant current power source to pass constant current through a helmholtz coil. I don't have much experience in power electronics.
Any kind of help will be appreciated.
Thanks.
johnpete001
Joined Jun 26, 2017
6
Welcome to AAC
Are you asking for some one to design it for you ?
I want someone to help me design it. I don't even know if what I am asking is actually a easy thing to design or not. But I have to design it to complete the project I am carrying out right now
Dodgydave
Joined Jun 22, 2012
11,395
Start by choosing a transformer that can give out 10amps or more any low voltage from 30V will do, then use an op amp and power transistor to set the current in the coil, plenty circuits on google.
R!f@@
Joined Apr 2, 2009
10,010
30V won't do.
Transformer secondary figures are for a 0-50VDC , 0-10A output:
To use a full bridge capacitive filter OP would need 42V @ 15Amps ( with headroom ) secondary rating.
To use a CT full wave capacitive filter OP would need 85V @ 11Amps ( with headroom ) secondary rating.
He need to choose the Tx depending on it's usage. For full continues operation, OP might need to beef up the secondary more than suggested for cooler operation.
WBahn
Joined Mar 31, 2012
33,245
Is this a project for school? If so, what are you expected to do as part of the assignment? Since you have to build it from scratch, it seems likely the idea is for you to design it as well. So sketch out the design as best you can and ask for thoughts and suggestions on it and then use those to improve your design.
WBahn
Joined Mar 31, 2012
33,245
Thanks.
What is the inductance of this coil?
What is the DC resistance?
What is the tolerance needed on the current?
How fast does it have to charge?
DickCappels
Joined Aug 21, 2008
10,661
Go get some larger wire. 10A x 263V = 2,630V. Not sure you could even buy a suitable power supply. Best to use larger gauge wire and try to get the resistance down to a few ohms.
BobTPH
Joined Jun 5, 2013
11,660
Tolerance needed on current is 0.1%.
That would be a lab quality instrument. Given the high power and high accuracy needed, not something an amateur (even one like me, who has been doing it for 60 years) is likely to succeed at.
Also, since you need 0.1% accuracy, you cannot have much ripple at all, which probably means a linear circuit, which means massive heat sinking capability. I would estimate this thing will weigh about 50 lbs and need lots of airflow for cooling.
Bob
ian field
Joined Oct 27, 2012
6,536
Thanks.
If you don't have much experience; PWM constant current is probably out of reach.
A 10A linear regulator handling up to 50v is going to be a lot of power transistors and a rather big heat sink.
You will probably end up using forced air cooling (fan).
