Hi, I have ordered the wireless temperature sensor reading the sensor at longer range but I need some suggestion to design a relay circuit which will be operated by wireless zigbee device.
I need to receive the data from wireless sensors and make the relay switch on or off the relay circuit. I am setting the range of temperature sensor and if the temperature goes above the range it will automatically switch on the power of relay.
Any suggestion to make this kind of criteria work will be a great help.
