I've recently entered the wonderful world of power electronics design and I'm a bit overwhelmed with a design I'm working on.
I would like to step-up a 3.3v supply to approximately 100v. I have some wiggle room on the exact voltage, and what seems to be an above average voltage ripple (say ~0.5v) is acceptable for this project. The output current requirements are low, at approximately 2mA. The design will be laid out on a PCB, where cost requirements and design size are flexible.
My question is what is the right path for me to be begin designing this circuit and what is feasible?
1) A single boost converter seems incapable of providing the step-up ratio. Using the equation D = 1 - (Vin * η)/(Vout), where η is the efficiency of the converter (I'll guess 0.9 as a reasonable value) and D is the duty cycle, D would have to be 97.03%. To the best of my understanding, this is an impossible duty cycle to achieve. Am I correct in this? Additionally, is 0.9 for η a reasonable assumption?
2) Using two boost converters in series, perhaps the first stepping up to 16v and the second from 16v to 100v. This gives duty cycles of 81.43% and 85.6%, respectively. Are two boost converters placed in series a good design? Feasible? Possible? If so, any recommendations on a regulator?
3) Using a flyback converter. I am most baffled here, as with all of the searching I have done I can't seem to find any reliable examples of stepping up a low voltage to a much higher one (e.g., 3.3v -> ~100v). To the best of my understanding, a step-up transformer with an appropriate turn ratio (approx 1:30) should be able to achieve this conversion. However, when using the TI WEBENCH tool, it doesn't seem to have any solutions to 3.3v -> 100v, usually stating that Vin is too low for the part. Are there concerns here that I'm missing? What would be a good place to start with this?
Any and all advice and help would be much appreciated! Thanks in advance.
