ANALOG Output design questions.
strantom
Joined Jan 21, 2025
8
I'm designing an analog output that takes a 0-5volt from a DAC and uses an op amp to step it up to 0-10volt, then turns it into a 0-20ma signal with a XTR111 and can use a switch to output 0-10v or 0-20ma. I want to make sure everything looks good before I start my first prototype.ScreenHunter 59.gif
strantom
Joined Jan 21, 2025
8
I seethe circuit but it is not clear just what connects to where.So I can't provide an answer.
AO.24 = 24volts in from external PSU for loop power
AO1 = output from the dac 0-5v then op amp turns it into 0-10v
%OW0 = output to the field device
AO1com = 24volts com from external PSU
AO1.1 & AO1.2 = go to the dip switch to swap from 0-10v or 0-20ma
hopefully this helps
ronsimpson
Joined Oct 7, 2019
4,812
Q22 has two things wrong with it.
U14 LM321 does not work well the inputs and outputs near the supply rails. I did not study the circuit well, but you might look for a R-R opamp designed for input & output voltage at the supply.
Should be fine as it duplicates the design from the data sheet.
no it does not.
ronsimpson
Joined Oct 7, 2019
4,812
The LM321, inputs do work at 0V but the output does not pull down well. The two 10K resistors are what is pulling down as you get below 0.7V. Just saying you have 20k pulling down when the OP gives up.
sghioto
Joined Dec 31, 2017
8,751
The LM321 has the same input configuration as a LM358 and it works to zero volt input.
Only need to change Q22 to a pnp type like a 2N2907.
