Design and simulate a circuit that takes as input a sinusoidal signal
adi80
Joined Oct 8, 2020
132
Yes Thanks all you guys.
Step2) Vin=0.05v Vout=1.14k Rin=10 so Rf=47k
Step3)Vin =0.05v Vout=0.25 Rin=10 so Rf=990k
ericgibbs
Joined Jan 29, 2010
21,623
hi adi,
Can we recap on the original question, do you agree with my summary of the question.?
E
A sinusoidal signal with peak-to-peak amplitude 0.2V, frequency 5kHz and offset 0.05V, and two outputs:
A sinusoidal signal at the same frequency as the input, peak-to-peak amplitude 2.2V and offset 0.55V.
A sinusoidal signal at the same frequency as the output, peak-to-peak amplitude 1.14V, and no offset.
Summary:::
Part1.
Vinput for both questions:
Vin= 0.2Vppk Sine-wave at 5kHz, with a +50mVdc input Offset
Part2.
The two outputs required, using the input as Part1 are.
Output1: 2.2Vppk with a +0.55Vdc offset
Output2: 1.14Vppk with no offset
ericgibbs
Joined Jan 29, 2010
21,623
hi aac,
It is difficult to help you further without giving you the answer.
Post what you think how the Vin source, using a simulation symbol, would be created.
A diagram or description will be ok.
E
Updated.
adi80
Joined Oct 8, 2020
132
What should i do next please?
I spent really 2 days here trying to learn from all of you. I did learn a lot in these two days to be honest.
I am sure you now have very clear idea that i don't have electronic brain but still i tried my best to learn.
ronsimpson
Joined Oct 7, 2019
4,853
I see you drew the schematic. Did you get it to simulate? This is what simulation looks like.
On my computer the input looks like this: peak to peak=0.2V and it is moved up by 0.05 volts.
My output looks like this: P-P=1.14 volts with no offset. (I added one resistor to remove the offset)
ericgibbs
Joined Jan 29, 2010
21,623
Is it black over.???
I assume you are using Windows 7,8 or 10
Use your capture screen image program and post a shot of the screen.
