Design and simulate a circuit that takes as input a sinusoidal signal
adi80
Joined Oct 8, 2020
132
When I open LTspice I also get a blank window. The I load the file and get a schematic like my bottom window.
Then when I push "simulation" which is the picture of a man running. Now I get a black window. At this point I need to click on what I want to measure or see. Click on the line "out" that the red arrow is pointing to. I added the red arrow.
I hope it helps to see what I see.
The question is asking for two Vout
adi80
Joined Oct 8, 2020
132
Hi Guys, so here i am back again. I managed to run simulation. please see attached pics and what you think.Final Schematic.pngFinal Schematic 2.png
adi80
Joined Oct 8, 2020
132
Well i really asked what pints those two sine sources where going to because it looks like the input offset adjust pins. Are you banking on those working as inputs also?
So do i need to remove that +15 and -15 and connect it there?
adi80
Joined Oct 8, 2020
132
Thank you very much Eric. I promise I will write the Report and share with you guys. Thank you once again.
ericgibbs
Joined Jan 29, 2010
21,622
hi,
You have do this part.
A sinusoidal signal at the same frequency as the output, peak-to-peak amplitude 1.14V, and no offset.
To do so, you must study and understand the first part, post#214
E
adi80
Joined Oct 8, 2020
132
hi,
E
Ok Eric I will study and will let you know if I still struggle (which I will) will come back here.
ericgibbs
Joined Jan 29, 2010
21,622
hi,
Right Click on the black plot area, drop down menu, left click on add Plot pane.
When you have two panes,place cursor on the Vout plot name and drag it down to the empty pane.
You can add more panes as you go.
E
