Independent on the implemented gain these data require a slew rate of app. 3600V/µs. (The unit as mentioned in the posting above provides only 2000V/µs).Example,for frequency 50 kHz and 30MHz output amplitude should amplify to 20 V.
Hi RichardO,No, you need a supply voltage greater (by a couple of volts typically) than the peak output voltage. By the way are you wanting 20 volts RMS, 20 volts peak or 20 volts peak-to-peak?
Here is an amplifier that has the best high frequency, output voltage swing and drive that I have found:
http://www.ti.com/product/ths6022
Be warned that this is a surface mount part and _very_ demanding on circuit board layout and power supply bypassing.
Hi Lvw,Independent on the implemented gain these data require a slew rate of app. 3600V/µs. (The unit as mentioned in the posting above provides only 2000V/µs).
To me, it would be helpful if you would summarize your requirementsHi Lvw,
I have a look on this chip it seem meet my requirement http://www.ti.com/lit/ds/symlink/lm7171.pdf
May you help me check it, does it suitable for my application?
Thanks
Woulde be up to 25Vp-P on this one actually.No, you need a supply voltage greater (by a couple of volts typically) than the peak output voltage. By the way are you wanting 20 volts RMS, 20 volts peak or 20 volts peak-to-peak?
Hi LvW,To me, it would be helpful if you would summarize your requirements
(gain, maximum frequency, maximum output amplitude, power supply restrictions).
5V for the amplifier (single supply)?maximun output amplitude = 20 Vpp
power supply= for my microcontroller is 5V supply
Hi LvW,5V for the amplifier (single supply)?
input of amplifier will be connected to the output of the AD9850 chip module and then the output impedance will let floating,yeah,i checked the amplifier ady,i think THS 6002 is suitable.xw0972,
I have no experience with the referenced units.
By the way - I forgot to ask what your requirements are regarding input and output impedance. That means: Why not use two discrete transistor gain stages in series?
I am afraid, it will be a problem to find an opamp that allows a gain of 100 with 10V peak output at a frequency of 40 MHz.
Did you check already current-feedback amplifiers? I think - if any, they provide the best chance to fulfill your requirements.
