Design a Sallen-Key lowpass filter
kentman234
Joined Dec 7, 2018
I have this task:
Design a Sallen-Key lowpass Butterworth filter with a 3 dB bandwidth of 8 kHz and 20 dB attentuation at 24 kHz.
Can you give me some hints?
Thank you.
kentman234
Joined Dec 7, 2018
yes. I think the normalized frequency for 20 dB is 24/8=3 Hz is that right?
So the 2nd order is enough. And what about calculating the elements?
I have the solution here. It says R=28.13 kohm, C1=1nF, C2=500pF.
bertus
Joined Apr 5, 2008
22,994
Without a schematic I can not tell you if the values are correct.
Have a look at chapter : 16.3.2.1 Sallen-Key Topology of the given PDF.
Bertus
