Let me know any micro controller based development board is there for below technical Specification.
24 bit (Minimum) A/D with 16 multiplexed analog inputs
16 Programmable Serial channels
Operating Temperature -20 0C to 55 0C
Battery backed Real time clock
Flash Disk Interface for 1 GB (min)
2 level Watchdog timers
EPROM /BIOS to store the setup,
Working voltage 9 - 16 Volts DC
Re-settable fuses shall be employed at the Power Outputs to sensors to protect the
system from individual sensor failure
Sensor Power controller (ON/OFF individual sensor)
Output for sensor power should be 12V DC ± 0.5 V
User friendly serial and analog sensor interface
External power recycle switch.
Recovery mechanism in case of system hang/failure
Option for debug display, The debug port shall display the current status of the CPU -
Data Acquisition details, sensor data, Modem transmission details
Battery health monitoring circuit.
Redundant Micro controller and its interface circuits for main system failure
CPU should consume low power such that the idle/sleep mode consumption to be less than
10mA and during active mode the current consumption should be less than 75mA at 12V DC
