DELTA CONFIGURATION
TAKYMOUNIR
Joined Jun 23, 2008
352
IN SOME 3 PHASE POWER SUPPLY ,THE INPUT OF THIS POWER SUPPLY IS DRIVEN FROM 3 PHASE DELTA NOT WYE AND THE REASON IS THE DELTA CONFIGURATION HAS LESS HARMONICS DISTORTION THAN Y SO WHY THE DELTA HAS LESS HARMONICS DISTORTION THAN Y
alfacliff
Joined Dec 13, 2013
2,458
because the other two phase windings are in paralell with the other winding. dosnt matter which winding yhou are talking about, the other two are in paralell, damps harmonics. in wye, they are not in paralel.
wmodavis
Joined Oct 23, 2010
739
Quit yelling TAK! Learn to use your shift key. When someone yells at me I just go somewhere else. Didn't even read your post.
TAKYMOUNIR
Joined Jun 23, 2008
352
CAN YOU PLEASE EXPLAIN MORE LIKE CAN YOU DRAW SOMETHING IF IT IS POSSIBLE
THANKS
bertus
Joined Apr 5, 2008
23,006
Is your shift key stuck?
Writing things in ALL CAPITAL letters is like shouting.
Please do not do this.
Dodgydave
Joined Jun 22, 2012
11,395
in Delta the windings go across two phases,which means they are in parallel, where as Star/Wye they are in series across two phases.
