DELL E1909WB Display problem
Hi Waqas,
I hope that you are fine.
The resistor that you are looking for is 22 ohms.
Can you please tell me the ic number LCDM Inverter Controller of this board.
Thank you.
MisterBill2
Joined Jan 23, 2018
27,683
The BAD NEWS is that resistors seldom burn so completely with out reason. So there is another problem that caused the resistor to be damaged. So until that problem is fixed a replacement resistor will also be damaged. Without additional information it will be very difficult to correctly guess which other part has failed.
