Deleted
  • Thread starter Deleted member 18830
  • Start date
Joined Dec 31, 1969
Deleted
Papabravo
Joined Feb 24, 2006
22,082
At one bit per FF you're going to need quite a few of them. You would be better off using a microcontroller for that purpose. If you still insist on a discrete logic implementation then I would suggest a gate array.
mik3ca
Joined Feb 11, 2007
189
a bit can store 2 states.
a byte stores 256 states.
The ascii system is at least 7 bits long, typically 8.
So to store 1 character, you need at least 4 7474's. you could use 1 74xxx73 (8-bit latch/flip-flop), but the best way to go is to use a microcontroller.
