Deleted
  • Thread starter Deleted member 18830
  • Start date
Joined Dec 31, 1969
Deleted
Ron H
Joined Apr 14, 2005
7,063
Eqn for low pass RC filter
(Vout/Vin) = (1/jwc) / ((1/jwc)+R)
R = 1khz
C=3.1847 x 10^-8
f= 50khz
Vin= 2v
Find Vout express in Db
My working:
i find the magnitude of both side which gives
vout = 2/ sqrt(1+R^2 w^2 c^2)
sub in all values i get vout = 4.997 x 10^-5
This is wrong. How did you get this? Show your steps.
change to db i get : 20log(4.997x10^-5) = -86.02db which is wrong:confused:
answer shld be around 5db
This is also wrong. Where did you get it?
what when wrong?
Thks.
to admin: Sorry for the "Urgent help needed" topic......pls remove it
rwmoekoe
Joined Mar 1, 2007
172
db = 20 log( vo/vi )
= 20 log( zc / (zc+r) )
= 20 log( (1/wc) / (1/wc+r) )
= 20 log( (1 / (2 pi 50k 3.18e-8) / (1 / (2 pi 50k 3.18e-8) + 1k) )
= 20 log( 100 / (100+1k) )
= -20 db
Ron H
Joined Apr 14, 2005
7,063
= -20 db
This calculation actually comes out to -20.83dB, which is wrong.
You forgot that the capacitor's reactance is 90 degrees out of phase with the resistance. You have to find the vector magnitude of the denominator.
Gain = 20 log( (1/wc) / sqrt((R^2) + (1/wc)^2)
Gain = -20.05dB
The OP wanted Vout when Vin=2V.
Vout=-14.03dB.
JoeJester
Joined Apr 26, 2005
4,390
Ron,
I got 198.9 mV as Vo, which is approximately -20.05 dB with respect to 2 Vi.
I didn't understand your Vo being -14.03 dB
Ron H
Joined Apr 14, 2005
7,063
Ron,
R = 1khz
C=3.1847 x 10^-8
f= 50khz
Vin= 2v
You got Vout=198.9 mV.
20 log (.1989) = -14.03dB.
You are correct in showing gain as -20.05dB, which will of course be true for any input voltage. I realize that dB is a unitless gain measurement (a ratio), but the OP said
Find Vout express in Db.
I suppose to be correct, we should say
Vout=-14.03dBV, i.e., relative to 1 volt, which identifies it as an absolute measurement rather than a ratio.
Ron H
Joined Apr 14, 2005
7,063
femtowatt.
I saw it on an HP signal generator back in the early 80s. Not one of the more popular references. :D
That's funny! Definitely engineering humor, though. My wife doesn't think much of any of my jokes or "funny" stories. I guess I won't try that one on her.:rolleyes:
JoeJester
Joined Apr 26, 2005
4,390
If I didn't have to look it up, I would have never remembered it. It was on the old HP-8640 signal generator series.
And to think 1 uV (50 ohms) is 130 dBf. The stuff people remember is amazing sometimes. :D
