Deleted
This is wrong. How did you get this? Show your steps.Hi,
Eqn for low pass RC filter
(Vout/Vin) = (1/jwc) / ((1/jwc)+R)
R = 1khz
C=3.1847 x 10^-8
f= 50khz
Vin= 2v
Find Vout express in Db
My working:
i find the magnitude of both side which gives
vout = 2/ sqrt(1+R^2 w^2 c^2)
sub in all values i get vout = 4.997 x 10^-5
This is also wrong. Where did you get it?change to db i get : 20log(4.997x10^-5) = -86.02db which is wrong
answer shld be around 5db
what when wrong?
Thks.
to admin: Sorry for the "Urgent help needed" topic......pls remove it
This calculation actually comes out to -20.83dB, which is wrong.db = 20 log( vo/vi )
= 20 log( zc / (zc+r) )
= 20 log( (1/wc) / (1/wc+r) )
= 20 log( (1 / (2 pi 50k 3.18e-8) / (1 / (2 pi 50k 3.18e-8) + 1k) )
= 20 log( 100 / (100+1k) )
= -20 db
The OP wrote:Ron,
I got 198.9 mV as Vo, which is approximately -20.05 dB with respect to 2 Vi.
I didn't understand your Vo being -14.03 dB
You got Vout=198.9 mV.(Vout/Vin) = (1/jwc) / ((1/jwc)+R)
R = 1khz
C=3.1847 x 10^-8
f= 50khz
Vin= 2v
I suppose to be correct, we should sayFind Vout express in Db.
Database Format? Divorced Black Female? Decibels (frequency)? I guess I'm not up-to-date on acronyms.That is true Ron. Had you stated dBV, there wouldn't be an issue. At least you didn't use dBf as the reference ...![]()
That's funny! Definitely engineering humor, though. My wife doesn't think much of any of my jokes or "funny" stories. I guess I won't try that one on her.femtowatt.
I saw it on an HP signal generator back in the early 80s. Not one of the more popular references.![]()
