Decoupling Capacitors
adam555
Joined Aug 17, 2013
858
I only see the electrolitic capacitors on your PCB.
I see none of the 100 nF capacitors ( C2, C4, C5 and C6 ) on your PCB.
They are a must for stability.
I'm afraid I left those out... I thought that: since I already had the big ones, why add the small ones; then tried it on a breadboard and it seemed to work well without them.
bertus
Joined Apr 5, 2008
23,027
Yes, as the stablility can not be garanteed.
Can you measure on the + 12 Volts and - 12 Volts with your scope?
Are the glitches visible on them?
adam555
Joined Aug 17, 2013
858
I think you got it. :)
There is a tiny, almost imperceptible ripple on the output of the positive regulator. I superimposed it to the output waveform from the FG, and bingo, it fits like a glove.
You are a star...
adam555
Joined Aug 17, 2013
858
Just checked the negative regulator, and there's a different ripple, this one fairly large (80mV p-p) almost in the form of a saw wave at 100Hz. This is what I saw before when I blamed the pot.
