decoder not working
marijannovak123
Joined Dec 16, 2014
3
Hello!
https://www.dropbox.com/s/tiknsfvfjhfq4ll/stepper.gif?dl=0
I am making a stepper driver, and connecting everything according to this diagram the decoder gives logic 1 only at q2 and q3 ..and they alternate in the constant rythm..q0 and q1 stay at logic 0 whole the time..when i try to connect decoder by itself and change the inputs myself it works as it's supposed to..but with the counter it doesn't..what could be the problem? thanks
jjw
Joined Dec 24, 2013
823
This may not solve the problem, but the 100 ohm resistance in the oscillator is way too low.
You could use 100k and change the capacitor to 1uF.
jjw
Joined Dec 24, 2013
823
Have you checked QA of the counter and A input of the decoder, are they changing?
They might be stuck at 5V.
Are the outputs of the decoder connected to something?
Edit: actually it might concern output QB and input B
ScottWang
Joined Aug 23, 2012
7,501
1. Please upload the file to the forum.
2. Change 10uf to 1 uf or less and try again.
3. If it still didn't work then you could in series another gate with clk(Pin 15).
marijannovak123
Joined Dec 16, 2014
3
Thanks everyone, I solved the problem. Apparently the B input was stuck at +5V although it's pin was changing voltage as the counter's outputs..anyway i grounded B, and used A and C..therefore I had to use different outputs too..so I'm using Y0,Y1,Y6,Y7
