Decade 4-bit Synchronous Counter using D flop flop (Divide-by-2 Counter)
JohnTZ
Joined Mar 30, 2015
4
Decade 4-bit Synchronous Counter using D flop flop (Divide-by-2 Counter): Modify the following circuit so that it counts up from "0000" to "1000" and then resets. Use either AND, OR and Inverters or NAND gates.
Any help is appreciate.
22,112
That is not a synchronous counter. In a synchronous counter the same clock line would go to all four flip flops. What you have drawn is called a ripple counter and it takes a while for the counter to go from one stable state to another.
JohnTZ
Joined Mar 30, 2015
4
Hello! Papabravo,
Thanks for info, could you please help me what should I do to modify the circuit to let it count up only from '0000' to '1000' instead of count from '0000' to '1111'?
Any hint is appreciate.
tshuck
Joined Oct 18, 2012
3,534
In addition to the thread MrChips linked to, I also wrote a thread on modulus counters, which you may find useful as it includes an example of designing a decade counter using JK flip flops. The approach is the same, but your input forming logic will change.
22,112
Hello! Papabravo,
HINT: All your flip flops must be clocked by a common clock signal.
HINT: Design a decoder for the state '1000'
That's two hints before breakfast.
