DC Voltage indicator using dual/triple colour LED
lisahxw
Joined Feb 23, 2009
2
Hi everyone, I am new here. Just wonder if anyone know how to design a DC voltage indicator using dual colour or ideally even triple colour LED, so it is function as follow:
Vout<11V red
{11V<Vout<12.5V orange}
Vout>12.5V Green
And anyway to make the reference adjustable.
Thanks.:)
bertus
Joined Apr 5, 2008
23,020
You will need two comparators.
One that switches the red off above 12.5 Volts and
one that switches the green off below 11 Volts.
Greetings,
lisahxw
Joined Feb 23, 2009
2
Erm............ I thought using comparators need a reference voltage. But in this case, it is to indicate the battery voltage level and there won't be an other power supply. How could the circuit designed to "know" the reference voltage?
Audioguru
Joined Dec 20, 2007
11,248
Use an LM3914 bar-graph LED driver IC. It has 10 comparators (use only 3 if you want) and an adjustable regulated reference voltage.
