I'm wanting to drive a 30Watt UV actinic fluorescent tube from a 12V battery for a moth trap. It's for attracting moths into a trap where they can be identified and released again unharmed.
The electronics I'm planning on using for this include a standard T8 ballast which is designed to run from 240V AC and an inverter.
To make life easy I was looking at inverter modules on eBay and found quite a few like this:
http://www.ebay.co.uk/itm/Hot-150W-...e=STRK:MEBIDX:IT&_trksid=p2055119.m1438.l2649
The specification of this states that it is a high frequency inverter @ 20KHhz!!! Given that my ballast would normally expect to run from a 50Hz supply, is this thing going to be suitable?
I apologise if this is a very silly question, but my field is in digital electronics!
