Not sure if i'm in the correct category but I need assistance with two things:
I'm looking for a way to either start/stop airflow via a valve of some sort in a schedule 40 4" diameter pipe or some kind of valve that will bleed off the pressure (low pressure down to 140" of water) in the pipe when opened. The start/stop method is preferred but i believe bleeding the pressure off would work as well. I also need a way to electrically control the opening/closing of the valves so the time is the same or repeatable each time. I'd like to be able to open/close it through several cycles and i'm looking for a way to do this as fast as possible. I have a four channel pc based digital oscilloscope that i plan on using to measure the open/closed times and I'm not really sure the best way to do this.
I've found some electronically controlled in-line butterfly valves but all the ones i could find appeared to be incredibly slow. I've also looked at some manual or mechanical vacuum relief valves but obviously they're not electrically controlled.
Any help or suggestions would be appreciated.
