DC Motor Wires Need Help
nuriberk2
Joined Jan 25, 2020
1
guys i got a dc motor from a rc car and it has 2 wires a blue one and a yellow one what do they do and which one is posotive and which one is negative???
Audioguru again
Joined Oct 21, 2019
6,826
RC airplanes, cars, helicopters and drones usually use a brushless DC motor that has three wires. It must be driven from a brushless motor electronic speed controller circuit, not simply DC.
djsfantasi
Joined Apr 11, 2010
9,237
Which way round you connect them will determine which way the motor rotates.
To elaborate on @AlbertHall’s post, there is no positive and negative wire. Connect the motor’s two wires like the following.
Blue wire to positive and yellow wire to negative. The motor will spin in one direction.
Then reverse the wires so the blue wire connects to negative and the yellow wire connects to positive. The motor will spin in the opposite direction.
What are you using the motor for?
30,674
Apart from what has been suggested, spin the motor in the original direction it was used in and measure the DC on the leads, one will be Pos, the other Neg. ;)
MisterBill2
Joined Jan 23, 2018
27,574
TS says it has two wires?
EXACTLY! Blue and Yellow are DC motor wire colors, and the TS states that it came from a RC car, but did not say that it was a new-style one. I have several RC cars and not a single one of them has a BLDC motor. Making a statement without adequate information provides no benefit.
Audioguru again
Joined Oct 21, 2019
6,826
All my RC airplanes that still work have brushless motors that seem to last forever.
All my RC airplanes that had the motors replaced many times had brushed motors.
All RC airplanes from Horizon Hobby that used a 1 cell Li-PO battery had brushed motors that soon wore out the brushes.
The newest RC airplane from Horizon Hobby that uses a 1 cell Li-PO battery has brushless motors.
MisterBill2
Joined Jan 23, 2018
27,574
Quite probably the TS is not taking a newest RC device apart. Brush type motors have been used in RC devices for at least 30 years, and so there are far more brush type motors in equipment that somebody might be taking a motor out of.
