Just picked up a dumped treadmill, FreeSpirit by Dyaco. The motor control board on this machine is different than any previous one I have seen. It is labelled YJ-2250L dated 2007/06/21. It has 12 wires from the panel down to the motor board (most have only 8 wires), labelled:
S/W - Black wire
DOWN - Brown
UP - Orange
VCC - Red
FAST - Yellow
SLOW - Blue
GND - Green
SPD - Violet
SPD - Grey
VR-1 - white
VR-2 - Pink
VR-3 - L/Green
I expect the S/W is the safety switch; up and down are self explanatory; VCC is normal (perhaps 12V or 5V); fast and slow are different to any other board I have worked on; speed (2 connectors) probably read the magnetic reed switch for belt speed; BUT the last 3, labelled VR 1, 2 and 3 I cannot figure out. Any ideas?
Does anyone know this board? Does it require pulses of VCC or Ground to the fast/slow pins, as it does not seem to use a potentiometer or PWM circuit?
Photo to follow as soon as I can.
S/W - Black wire
DOWN - Brown
UP - Orange
VCC - Red
FAST - Yellow
SLOW - Blue
GND - Green
SPD - Violet
SPD - Grey
VR-1 - white
VR-2 - Pink
VR-3 - L/Green
