DC motor speed control project
IbrahimF
Joined Jul 21, 2017
25
Hello
I am currently making a bridge rectifier to convert AC to DC and connect the output to a motor, however, I need a circuit after the bridge rectifier to control the speed of a 15V DC motor. I am getting 19V output from the AC to DC converter.
This is the AC to DC converter with a capacitor to smooth the output.
I am still missing the motor control circuit and I need two aprooches
1. Using a variable voltage regulator.
2. Using a MOSFET switched supply.
I have managed to get this circuit but it's not working for some reason I am not sure if it's the software. or if the circuit is wrong can someone please clarify if the circuit is ok can control motor speed.
also, how can this achieved using a variable voltage regulator
Thanks
Thanks
IbrahimF
Joined Jul 21, 2017
25
in addition, the torque HP doesn't matter. all whats required is just two different circuits to control the motor speed.
One using a MOSFET switched supply and the other a variable voltage regulator
Thank
30,655
When using the 555/PWM type circuit to control a DC motor you do not need to size the supply to the motor voltage, in fact it is preferable to be ~10% above, min.
If using the DC supply with no control, i.e. direct on, you do not require a Capacitor across the bridge output on a 15vac supply.
