So I have a 90V DC motor for a CNC machine. I need a controller for it. I'm not sure of the motor's power (no datasheet that I can find)
If I run it from my PSU which goes up to 30V, it draws about 0.3A
Assuming that I don't need it to go in both directions, is there any good reason why I shouldn't do this: use a stepdown transformer and bridge rectifier to give me 90V DC, and switch it on and off with a relay. Use a hefty rheostat as a voltage divider to vary the speed. Add a rectifier to guard against back EMF.
If I wanted to go a step further and control the speed with an input voltage (0-10V) could I do this with a power transistor?
