DC motor application
Francoisdut
Joined Feb 23, 2009
2
Good day
I need to design a circuit that needs to do the following: it must be a bidirectional dc motor speed controller using a lm35 temperature sensor as reference for the speed of the the DC motor.
Any help or suggestions will help.
bertus
Joined Apr 5, 2008
23,014
What must happen ?
What is the LM35 used for ? Temperature measurement ?
What is the relation between temperature and motor movement ?
Greetings,
Francoisdut
Joined Feb 23, 2009
2
The LM 35 is used for measuring temperature. When the temperature increases the speed of the motor must also increases. The motor must also be able to turn forward and backwards with the use of a switch.
Greetings
Francois
