hi everyone!
I assembled the circuit as shown in the attached image. However, some of the results diverged from the calculated values. The currents in inductors L1 and L0 are significantly higher than expected.
I would appreciate any tips on what could be adjusted in the circuit to improve the results and bring them closer to the specified values.
I used in LTspice, a simulation I conducted in Psim with an ideal model of the converter.
For the conditions I specified, the currents in inductors L1 and L0 should be 4 A and 10 A, respectively, but both are showing an average value of 14 A. I suspect there may be an issue with the circuit. I would be grateful for any advice, insights, or guidance you could provide!
