The surface mount devices have unusual codes and don't necessarily correspond to the part number - they are center reused by other manufacturers - there is just not enough space in these tiny parts.Thank you for your answer MrSalts. It seems to be a Mosfet as you have noticed, but I'm unable to find anything on the web related to the reference silkscreened and I have to replace the IC.
Hi MrSalts. Thanks again for your suggestions!The surface mount devices have unusual codes and don't necessarily correspond to the part number - they are center reused by other manufacturers - there is just not enough space in these tiny parts.
Can you measure the size of the part (with and without the leads). Also, measure the width of the traces leading to/from the part so we can estimate the current. What type of decide and what power rating does it have?
