dc-dc converter don't boost
thanosP
Joined Jan 18, 2018
5
Hello , i need ur help
I made a dc-dc converter but the Vout its is exactly the same with Vin.
Can anyone have an idea what i got wrong?
Vin=12V
L=0.1uF
C=10mF
R=1Ω
The pulse generator have period=2*10^(-6) and pulse width=22%
thanosP
Joined Jan 18, 2018
5
i just made the switch to be controlled with this logic :
and is just the same .
I have the same waveform in the output.
Have u an idea how to solve it?
Thank you for your reply
sghioto
Joined Dec 31, 2017
8,634
Current sensor 1 is in parallel with the output through a 1 ohm resistor. I surprised you have any output at all with that arrangement.
Steve G
thanosP
Joined Jan 18, 2018
5
Thank u all for your replies. I want to ask something more.
I made this circuit :
and the results i take is
(yellow line) Vinput is synphasic with the current of inductor(blue line)
This is what i want.
But the voltage in resistor is lower than Vinput and also is ac .
I dont know why i cant take a dc voltage in output
And why this voltage isn't bigger than the Vinput?
Vin=0.4V
L=850uH
C=1mF
R=1.3Ω
I am in basics , so i am sorry if these questions are obvious for you.
Thank you all for your replies
AlbertHall
Joined Jun 4, 2014
12,625
Which is what you would expect. You have no reservoir capacitor on the output of the bridge rectifier so when the rectifier output follows the AC input therefore the inductor/switch/diode output must also follow that voltage.
