DC-DC Buck Regulator suggestions
LewLex
Joined Jul 15, 2025
11
Hi. I hope this is the correct forum to post this in, but I wondered if anyone has any suggestions as i'm struggling to find a DC-DC buck that matches the below characteristics:
- Input Voltage will be between 4.2V-3V (Lithium-ion Battery)
- My desired output Voltage is 2.5V (this is normally adjustable with resistors)
- Output current rating needs to be 8A or higher. (at 2.5V the load will be ~6A)
its basically to take a lithium battery voltage, and give a 2.5V rail
thanks in advance
BobTPH
Joined Jun 5, 2013
11,662
Not surprising because the MOSFET switch is likely to need more than 3V. I can find some that go down to 4V, but no lower.
I would look into building your own with a BJT switch, or a very specialized low Vgs threshold MOSFET.
BobTPH
Joined Jun 5, 2013
11,662
If you look closely, they can take an input voltage below 3V but they need an additional 3.3V or 5V “ bias” supply for the logic.
