DC DC boost converter
Said76
Joined Jul 11, 2018
11
Bonjour. Je souhaiterais obtenir des informations et des explications concernant le fonctionnement du MOSFET dans un convertisseur DC-DC élévateur. Par exemple, lorsque le MOSFET est conducteur, le courant circule dans l'inductance, mais pas dans la charge. Je ne comprends pas pourquoi. En effet, il existe une règle stipulant que le courant emprunte le chemin de plus faible résistance.
Moderation translated, please use English text.
Hello. I would like to obtain information and explanations regarding the operation of the MOSFET in a boost-up DC-DC converter. For example, when the MOSFET is conducting, current flows through the inductor, but not through the load. I don't understand why. Indeed, there is a rule stating that current takes the path of least resistance.
lichurbagan
Joined Jul 4, 2025
137
A boost converter increases voltage from input to output. It has an inductor, MOSFET, diode, capacitor, and load. When the MOSFET is ON, current flows through the inductor. The diode is reverse-biased, blocking current to the load. The inductor stores energy while the MOSFET conducts. Current always follows available paths, not blocked ones. When the MOSFET turns OFF, the inductor pushes current out. The diode becomes forward-biased, allowing current to the load. Energy stored in the inductor transfers to the capacitor. This cycle repeats, boosting the output voltage above the input.
38,822
That is a commonly stated but misinterpreted "rule".
There is no "all" in front of the word current.
Certainly more current will flow through the path of "least resistance", but some current will also flow down any other parallel paths of finite resistance.
Said76
Joined Jul 11, 2018
11
Said76
Joined Jul 11, 2018
11
Un convertisseur élévateur augmente la tension d'entrée à la tension de sortie. Il est composé d'une inductance, d'un MOSFET, d'une diode, d'un condensateur et d'une charge. Lorsque le MOSFET est conducteur, le courant circule dans l'inductance. La diode est polarisée en inverse, bloquant ainsi le courant vers la charge. L'inductance emmagasine de l'énergie pendant la conduction du MOSFET. Le courant emprunte toujours les chemins disponibles. Lorsque le MOSFET est bloqué, l'inductance laisse passer le courant. La diode devient alors polarisée en direct, permettant au courant d'alimenter la charge. L'énergie stockée dans l'inductance est transférée au condensateur. Ce cycle se répète, augmentant ainsi la tension de sortie au-dessus de la tension d'entrée.
Thank you for your reply
Said76
Joined Jul 11, 2018
11
Il s'agit d'une « règle » couramment énoncée mais mal interprétée.
Il n'y a pas de « tous » devant le mot courant.
Certes, le courant circulera davantage par le chemin de « moindre résistance », mais un certain courant circulera également par tout autre chemin parallèle de résistance finie.
Thanks for your reply
Said76
Joined Jul 11, 2018
11
i am sorry thank you for your translation
Plamen
Joined Mar 29, 2015
111
In the Boost topology, the switch is low side i.e. pulling down in on state. The diode decouples from the output capacitor, holding the load during on time. Upon turning the switch off, the inductor kicks and adds its voltage to the input one.
The input current is continuous (always through the inductor), the output current is choppy (only during the off time). In this sense the boost resembles the fly-back (energy transfer during off time)
Said76
Joined Jul 11, 2018
11
Dans la topologie Boost, l'interrupteur est à la masse (il tire le potentiel vers le bas lorsqu'il est passant). La diode se découple du condensateur de sortie, maintenant ainsi la charge pendant la conduction. À la coupure de l'interrupteur, l'inductance entre en action et ajoute sa tension à celle de l'entrée.
Le courant d'entrée est continu (il traverse toujours l'inductance), tandis que le courant de sortie est intermittent (uniquement pendant la période de blocage). En ce sens, le convertisseur élévateur ressemble au convertisseur flyback (transfert d'énergie pendant la période de blocage).
thank you for your reply
