DC analog signal
maduba12001
Joined May 12, 2020
9
I would like a advice on how to filter out the DC analog signal that comes out from analog multiplexer. It contains noice kind of spike. I very much appreciated if you could reply me back soon as possible. Thank you
35,291
Start by showing us a circuit diagram of what you have, showing all part numbers and component values.
Audioguru again
Joined Oct 21, 2019
6,826
You said "noice" but we spell it "noise".
A signal spike in music might be part of the music. If somebody is speaking the spike might be a cough.
Years ago a scratch on a vinyl record produced a large spike that was reduced by a pop-reduction circuit.
Why does your analog multiplexer produce a large spike?
38,932
If the noise spike occurs when the mux is switching channels, that's the capacitive feedthrough from the gate control signal to the signal channel.
That can possibly be reduced by filtering or reducing the signal source and/or load impedance.
Using a MUX with a lower feedthrough capacitance will also help.
drjohsmith
Joined Dec 13, 2021
1,670
There are many old mux's that had this problem on switching,
causes a huge spike
audio pre amps used to blank outputs of mux's to absorb spike,
modern mux's have much less feedthrough
whats the part,
as said above, show us your circuit
