Hi. I am measuring a voltage from Thermopile in millivolt, (although the millivolt is amplified with the help of INA-333, a pre-prepared CJMCU-333 has been taken for this purpose), similarly, a bolometer (changes need to be seen in microvolts) needs to be measured. The software needs to be created in Labview for the above-mentioned purposes. Can you suggest me the best type of A/D Convertor which can be used with Labview.
I was thinking of using Rasberry Pi along with ADS1115 (16 Bit) and Labview System installed within the RPi. Should I go ahead with it?
