DAC trouble with finding parts
ducher
Joined May 17, 2017
47
Have you tried the PART SEARCH function on this website. The link is "PART SEARCH" in the upper-right corner of this web page.
hey, thanks for your reply, yes i have tried that but When I click on the capacitor icon, I can choose from many different types.
I don't know wich type i need for this cuircet, it has to be solderd on the service of the pcb and has to be very small.
can you tell me which one i need?
ducher
Joined May 17, 2017
47
does a 1/10W resistor means that it can handle 1 to 10 W or that it can handle a maximum of one tenth of a Watt?
DickCappels
Joined Aug 21, 2008
10,661
"1/10" is a fraction. 1/10 W means it is rated at 0.1 watts.
As for capacitors, the information is in the bill of materials. Below is the third component in your list.
The capacitor type is chip and the size code is 0603, the value is 0.1 uf (microfaradP = 100 nf (nanofarad) = 100,000 pf (picofarads). It is a ceramic capacitor. The tolerance of the capacitance is ±10%, the voltage rating is 25 volts, and the dielectric is X5R ceramic.
Other ceramic capacitors in you bill of materials are COG type ceramic -type NPO is the same stuff by a different name.
The capacitors 10 uf and above are electrolytic. The type is indicated as "tant" means Tantalum,
ducher
Joined May 17, 2017
47
thank you very much for the explanation.
ducher
Joined May 17, 2017
47
I found some components on digikey. with the search filter. But there are 50 kind of different compasitors with 0.1uF, 10% 25V X5R.
Does it matter wich one i choose or will it work anyway when it has at least those specifications?
thankss
DickCappels
Joined Aug 21, 2008
10,661
It should not matter in most cases which capacitor you get as long as the size code, capacitance, voltage, and dielectric match.
Yes, that looks like a chip type ferrite bead.
ducher
Joined May 17, 2017
47
thanks for your reply, What is the difference between C0G,NPO and C0G,NPO (1B)?
and between CAP CHIP and CAP CER?
ducher
Joined May 17, 2017
47
i need the PCM1794A When i search for it i can choose 2 components, the 595-PCM1794ADBR and the 595-PCM1794ADB. The only difference i can find about the 2 is the price (second one is 3 dollars expensiver). Can anyone tell me what else is different between these 2 components. and which one i should choose.
The weirdest thing is..... they have the SAME datasheet :0 :0 :0 :0
Thank you very much
DickCappels
Joined Aug 21, 2008
10,661
The Wikipedia article at the link below describes the differences among types of ceramic very clearly.
https://en.wikipedia.org/wiki/Ceramic_capacitor
I am not sure how to answer your second question.
Thank you very much
From the datasheet, there is no difference between the ICs.
ducher
Joined May 17, 2017
47
thanks, sorry for the many questions but i don't want to ruine my DAC because of the wrong components 300.
I have one more question.... i'm looking for the ferrite chip (see attached file)
But i can't find a feritte chip with 300 micro ohm. Het laagste wat ze op digikey hebben is 1.5 ohm.
bertus
Joined Apr 5, 2008
23,010
The value of an inductor is given in Henry and not in Ohms.
It is likely a 330μH inductor.
The DC resistance will determine the max current allowed.
Bertus
ducher
Joined May 17, 2017
47
Bertus
so 300 mR has to be 300 mH?
a ferrrite chip is a filter not a inductor am i right?
ducher
Joined May 17, 2017
47
Hallo,
I think so.
(Ik denk het wel.)
Bertus
Als je het gewoon in nederlands wil weten, dan zou je eens op het http://www.elektronicaforum.nl/ kunnen kijken.
Daar zijn Stynus en SMD_lover wel enigsinds bekend met de onderdelen.
bedankt voor je reactie, ik heb een ceramic capacitor chip nodig (6030) van 430pF 25V C0G.
Deze zijn helaas niet beschikbaar of ik moet er meteen 4000 aanschaffen haha.
Weet jij misschien een goede site die ze wel verkoopt?
zou ik ook een andere waarden kunnen gebruiken?
Het is C9 (zie bijlagen)
alvast bedankt voor je reactie!
DickCappels
Joined Aug 21, 2008
10,661
Requiring a COG capacitor in that place in the circuit is very unusual. If really needed to be COG that would mean that the circuit is on the verge of oscillation, and then the tolerance of the capacitor would likely be a problem.
It is very likely that an X7R or P100 would work well there.
ducher
Joined May 17, 2017
47
with the same values?
there are no capacitors with the value 25V 430pF X7R :(
what's important to look out for when looking for the right resistor?
should I choose the highest power over the resistor available (1/10)?
