CWVM - Is it just a measurement error ,, ??
Mars Park
Joined Feb 20, 2022
37
It is a CWVM circuit consisting of two stages. (Common ground)
The voltage of 578V was measured in the first capacitor and 582V in the second capacitor.
So, if I measure the second capacitor from the ground, I thought that there would be about 1160V.
But,
The multimeter shows 437 volts. The internal resistor of multimeter is 10M. (No resistor in probe.)
Is it because the ESR of capacitor is too high ??
And then i used 80k-6. (high voltage probe)
The result is below.
(It show as a value of one thousandth due to the voltage divide.)
Which value is correct ??
34,826
The internal resistance of the DMM is 10MΩ.
For 10% error your measuring device must have an internal resistance that is 10 times (or higher) than that being measured.
Your HV probe has an internal resistance of about 75MΩ, i.e. 8 times higher than the DMM.
Mars Park
Joined Feb 20, 2022
37
In conclusion, is the value measured by HV probe close to the actual voltage?
