Hi Guys,
I'm hoping to sense the current through a P-channel Mosfets Source (12V+) giving a range of 0 - 3.3V on the output of a diff opamp setup. One consideration is the voltage of the 12V is automotive and will change with the alternator running or not, possbily up to say 14V also if a car battery discharges to 12V or less (god forbid). I do realise considering this is differential config, it should be fine, but I just wanted some opinions on the differential opamp resistor values. I was hoping to use it for short circuit protection (over 35 to 40A). The reason I'd like the output to be less than 3.3V is to trigger a uC to switch off the mosfet until it's power cycled (to prevent an intermittant short from continuously arcing). I was also considering using a TL431 on the output as an "instant" mosfet gate switch.
i found this calculator online and reaslise it's for when ground is connected to the sense resistor, but i wasn't sure that would be a problem considering we're just dealing with differential and gain.
Any help would be appreciated.
