i want to design a circuit that limits the current range to provide protection against high current. I want to use a Schmitt trigger in this design. How can I do this? For example, I want to provide protection between 2 amperes and 15 amperes. When the current falls below 2 A, the circuit should shut down, and when it exceeds 15 A, the circuit should shut down. I want it to operate only within these two values. I am considering using a shunt resistor for current measurement.
Is there an alternative I can use instead of a Schmitt trigger to set these two current thresholds?
Can you help me with this?
