Hi all,
I am using LTC3892 step down converter for my Battery Management System. I need current limit at various steps, For eg, If the maximum current is designed to be 20amps, I need current to be limited at 5A, 10A, 12A, 15A, 18A. For this, I need a idea to implement a circuit. According to the functional block diagram of LTC3892 datasheet, current can be limited by changing the voltage at feed back pin, Vfb pin. Is that correct, If so I need a analog circuit to limit the current changing the Vfb pin. Please give me some suggestion to limit the current.
