If i wrote them in a bigger font will you be able to give me feedback?Hello Ramiel,
The pictures have to less information to get them enhanced, as I did before.
Do you have a flatbed scanner?
My printer here at home has one.
If the first picture is only meant to provide the circuit, then crop the other stuff out. Don't make the reader have to guess what is and what is not important to trying to follow what you are trying to convey. Remember, you are asking strangers for free help -- YOU need to make it easier for them to WANT to do that.The firs
the first picture is only meants for the circuit
Look at the other pictures for the work
It's not the size nearly so much as it is the contract and the sharpness (contrast, primarily).If i wrote them in a bigger font will you be able to give me feedback?
Just look at the solutions and you will see that your assumption that those equations work is wrong!
But let's assume they aren't.
You are claiming
i1=i*L1/(L1+L2)
and:
i2=i*L2/(L1+L2)
A direct consequence of this is that, at all time,
i2(t) = i1(t)·(L2/L1)
Since L1 = 6 H and L2 = 3 H, that means that
i2(t) = 2·i1(t)
What is i1(0)?
It is given that i1(t) = 0.6 A e^(t/0.5 s)
That means that i1(t=0) = 0.6 A.
Thus, you're claiming that i2(t=0) = 1.2 A
But we are also given that i(t=0) = 1.4 A.
Since
i(t) = i1(t) + i2(t)
i2(t = 0) = 1.4 A - 0.6 A = 0.8 A
Therefore, contrary to what you are assuming, those equations do not hold for this problem.
The reason why not is very simple and I have stated it repeatedly. I see no utility in stating it yet again -- go back and DO THE MATH!
This method holds for specific situations. For example if you tried it here, it wont workHi,
Did i type that wrong?
I meant this:
i1=i*L2/(L1+L2)
and:
i2=i*L1/(L1+L2)
I hope you can take a look at post 45 and give me some advice on how to find i2(0)Hello,
When you would have written the papers with a black pen instead of a pencil, they already would be better readable.
I hope you can check post 45 and give me feedback on how to get i2(0)It's not the size nearly so much as it is the contract and the sharpness (contrast, primarily).
Hello again,I
if i an able to find either i(0) or i2(0), i would be able to find the other using i= i1+ i2
But i am not able to find either
Hi,This method holds for specific situations. For example if you tried it here, it wont work
Try it with the question in post 47, and the answer using your method will be wrong since it doesnt always hold to be trueHi,
Really? Then how did i get the right result using that idea? Is the book wrong?
Doesn't matter. These equations do NOT hold for this problem because this problem does not abide by the assumptions that are required to be true in order for those equations to apply!Hi,
I meant this:
i1=i*L2/(L1+L2)
and:
i2=i*L1/(L1+L2)
1) I really hope you took some time to see my attempt in post 45 as i wrote it clearlyDoesn't matter. These equations do NOT hold for this problem because this problem does not abide by the assumptions that are required to be true in order for those equations to apply!
DO THE MATH!
Or, at the very least, explain why the provided solutions to the problem do not satisfy the relationships that you keep insisting hold. If the solutions are wrong, then show that they are wrong. If they are not wrong, then how can you keep insisting that the current divides as you say it does here?
Since doing the math seems to be asking way too much, at least follow along as I do it, step by step.
You have an inductor, L1, that has a voltage v(t) applied across it. What is the current i1(t)?
For an inductor in general:
v(t) = L di(t)/dt
so
i(t) = ∫v(t)/L
i1(t) = i1(0) + (1/L1)·[∫v(τ) dτ evaluated from 0 to t]
You have another inductor, L2, that has this same voltage applied across it. What is the current i2(t)?
i2(t) = i2(0) + (1/L2)·[∫v(τ) dτ evaluated from 0 to t]
Solving for the integral, we get
[∫v(τ) dτ evaluated from 0 to t] = L2(i2(t) - i2(0))
Plugging this back into the expression for i1(t), we get
i1(t) = i1(0) + (1/L1)·[L2(i2(t) - i2(0))]
i1(t) = i1(0) + (L2/L1)·[i2(t) - i2(0)]
i1(t) = (L2/L1)·i2(t) + [i1(0) - (L2/L1)·i2(0) ]
Similarly, we have for i2(t)
i2(t) = (L1/L2)·i1(t) + [i2(0) - (L1/L2)·i1(0) ]
Since
i(t) = (L2/L1)·i2(t) + [i1(0) - (L2/L1)·i2(0) ] + i2(t)
i(t) = ((L1 + L2)/L1)·i2(t) + [i1(0) - (L2/L1)·i2(0) ]
So i2(t) in terms of i(t) is
i2(t) = [L1/(L1 + L2)]{i(t) - [i1(0) - (L2/L1)·i2(0) ] }
i2(t) = [L1/(L1 + L2)]·i(t) + [L2·i2(0) - L1·i1(0)]/(L1 + L2)
Can you NOW finally see what I have been saying over and over?
You are insisting on assuming that the initial currents in the inductors are either zero or, at the very least, are in the same proportion as the inductances.
This is simply NOT TRUE for this problem. The initial conditions are very explicitly given and they simply are NOT in this proportion!
Please show how you got the book's result using that idea, since the book's result is completely at odds with your claim.Hi,
1) It is much clearer -- I'll try to take a look at it when I have some time (more than I do right now).1) I really hope you took some time to see my attempt in post 45 as i wrote it clearly
2) i understand the math and i am working by the math and not the division rule
3) are you refering to the question i posted when giving the explanation because the voltage across l1 and l1 is not v(t)
The book’s answer is right. I solved it. If you want a detailed answer i would do it.Please show how you got the book's result using that idea, since the book's result is completely at odds with your claim.
Show how that idea leads to:
i2(t) = (-0.4 + 1.2e^(-2t/sec)) A
If the book's answer is correct, then
i(t) = (-0.4 + 1.8e^(-2t/sec)) A
Since i1(t) is given as
i1(t) = 0.6e^(-2t/sec)) A
And since you claim that
i2(t) = i(t) * L1/(L1+L2)
Please show how
i2(t) = (-0.4 + 1.2e^(-2t/sec)) A = [(-0.4 + 1.8e^(-2t/sec)) A ]* [L1/(L1+L2)]
Hi again,Doesn't matter. These equations do NOT hold for this problem because this problem does not abide by the assumptions that are required to be true in order for those equations to apply!
DO THE MATH!
v(t) = L di(t)/dt
so
i(t) = ∫v(t)/L
Since
Hi,Please show how you got the book's result using that idea, since the book's result is completely at odds with your claim.
Please show how
Hi,The book’s answer is right. I solved it. If you want a detailed answer i would do it.
I first tried the way @MrAl mentioned using division rule, but it is not right.
